Engine died and will not restart
- micytrap
04 Aug 2015 18:21 #149024
by micytrap
Engine died and will not restart was created by micytrap
Hi Guys,
I have a 1999 Jimny with the G13BB engine.
Was driving to work the other morning and it just died. It was as though it ran out of fuel even though the tank was over 1/2 full.
Towed it home and started to look over the possibilities. Diagnostic tool reported no faults in the ECU - battery is fully charged - great fuel pressure - replaced can angle sensor, throttle position switch and MAP sensor, but no change. All fuses checked good.
Engine cranks quickly, but not starting. Noticed that even though the handbrake is down, the handbrake light comes on when swinging the engine - never noticed this before!
Opened the air filter cover and sprayed a burp of starting fluid in the intake whilst cranking - started right up until the fuel burnt away. Checked the injector wiring and appears that there is no pulse coming when cranking.
Replaced the ECU - no change. What next to look for?
Lost earth to ECU?
Power to ECU?
Keyswitch power to ECU?
Any help greatly appreciated!
Lost earth to ECU?
Power to ECU?
- mickt
04 Aug 2015 18:36 #149026
by mickt
Replied by mickt on topic Engine died and will not restart
Immobiliser playing up. Might need a new key. My local shoe repairer/keysmith can do them for £45 as his reader can read the fob. I do not know what the dealers charge though.
- Al.
04 Aug 2015 19:00 - 04 Aug 2015 19:07 #149028
by Al.
Replied by Al. on topic Engine died and will not restart
Im assuming this is petrol, check the wiring harness for breaks. Also before blaming the immobiliser, i would check what the immobiliser kills, because you said it starts with fuel down the filter, Immobiliesers tend to kill spark.
a bad tip. pull spark plug caps off, wind the engine over a bit, and remove plugs,, are they wet with fuel.
Wet ignition issue
Dry fuel issue.
Wet ignition issue
Dry fuel issue.
Last edit: 04 Aug 2015 19:07 by Al..
- micytrap
04 Aug 2015 19:27 #149033
by micytrap
Replied by micytrap on topic Engine died and will not restart
Thanks for your reply!
This car has no immobilizer and the keys are just steel, no plastic head.
Mike
Mike
04 Aug 2015 19:27 #149034
by Rhinoman
Replied by Rhinoman on topic Engine died and will not restart
When you replaced the ECU did you replace it with a matched set, ECU, immo and keys? The handbrake light coming on might indicate an earthing problem.
- Al.
04 Aug 2015 19:31 #149035
by Al.
I would go through the wiring, check for it rubbing against the bodywork, and as Rhino said, check earths.
Time to create page: 0.111 seconds
