Upgrading bolts
  • fshdck
11 years 3 months ago #148915 by fshdck
Upgrading bolts was created by fshdck
All bolts and fitting on my car are rusted through. Anybody thought of using stainless steel bolts instead? The pros are obvious, are there any problems stainless would cause, apart from higher cost?
11 years 3 months ago #148916 by Lambert
Replied by Lambert on topic Upgrading bolts
Yeah, in high tensile application a stainless steel bolt will not be strong enough. There's a thread on here somewhere about this.
  • fshdck
11 years 3 months ago #148917 by fshdck
Replied by fshdck on topic Upgrading bolts
I suspected something along these lines. Thank you.
11 years 3 months ago #148921 by facade
Replied by facade on topic Upgrading bolts
Also stainless into alloy causes corrosion and the bolts will never come undone again.
11 years 3 months ago #148924 by kirkynut
Replied by kirkynut on topic Upgrading bolts
Use waterproof grease upon assembly every time you work on it and eventually, like me you'll have had the car completely apart and will have done this everywhere.
Obviously use new standard bolts when you first strip each part of the car.
11 years 3 months ago #149061 by auchenblae
Replied by auchenblae on topic Upgrading bolts
The normal stainless bolts on Ebay are A2 grade stainless and less strong than carbon steel grade 8.8 that most good quality bolts are made from.
Stainless grade A4 is getting there but and it is a big but.
Most normal available Stainless bolts do not have the give that carbon steel has and tend to brake rather than having that touch of elasticity in let's say a suspension member getting a shock loading after hitting a deep pot hole.
The carbon steels gets it and carries on the stainless has a tendency to fail.
Therefore do not use stainless in these applications and of course the similar metal corrosion issues.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Time to create page: 0.094 seconds
