suspension torque settings
01 Aug 2015 13:47 #148807 by Mike G
Going to be fitting my new suspension next weekend, but wondered what the torque settings would be on the shock bolts. I'm also fitting new super pro bushes to the radius arms (chassis and axle), but can't find any info on those either. Does anyone have any hints?
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
  • Decklandpt
01 Aug 2015 14:15 #148809 by Decklandpt
Replied by Decklandpt on topic suspension torque settings
check this.
i have a pdf with the repair manual somewhere one another computer,and it looks just like this but was 56mb and this one is 26 i think, but i think it's the same thing, it's bound to be there somewhere
  • gusthegorilla
01 Aug 2015 14:17 #148810 by gusthegorilla
Replied by gusthegorilla on topic suspension torque settings
Front Shocks, upper & lower............90nm
Rear Shocks, upper & lower.............85nm
Radius arms, front & rear................90nm
Figures taken from Suzuki Jimny digital W/S manual, available on Ebay for about a fiver ;)
Hope this helps,
Gus :)
  • Decklandpt
01 Aug 2015 14:17 #148811 by Decklandpt
goddamn tags are messed up, here´s the link
pdfziel.com/doc/1251-suzuki-jimny-sn-413-service-manual
01 Aug 2015 15:04 #148817 by Mike G
Replied by Mike G on topic suspension torque settings
Thanks guys,
That should do the trick.
Mike
  • wombat
01 Aug 2015 21:11 #148858 by wombat
Replied by wombat on topic suspension torque settings
Just remember to torque the bolts up with the wheels on the ground so the suspension is in its normal position, if its torqued up with no load on it it could cause premature bush wear
Time to create page: 0.117 seconds
