where do I get wheels bearings ???????
  • miniman899
31 Jul 2015 17:18 #148775 by miniman899
where do I get wheels bearings ??????? was created by miniman899
Hi people
everywhere seems to be sold out where do people get there front wheel bearings . I dont want the cheap nasty ones that are tapered they last 5 minute's .
cheers
tom
31 Jul 2015 18:00 - 31 Jul 2015 18:21 #148777 by Jezz
Have you tried the Big Jimny shop?? Edit, I see there out of stock too.
It's been fettled just a tad.
Last edit: 31 Jul 2015 18:21 by Jezz. Reason: Editing
  • mickt
31 Jul 2015 19:47 #148782 by mickt
Replied by mickt on topic where do I get wheels bearings ???????
Try this supplier They have them in stock at £24.95 each.
www.febest.eu
Superb service and quality item. I have had a few bits from them and they are cheaper than here. Good transit time too!
01 Aug 2015 08:37 #148791 by Busta
Visit your local bearing supplier! There will be one not far from you. They are a standard bearing. They might have the seals too. If not, they can be bought online very cheaply.
The bearings are a 30302 (15x42x14.3mm taper roller bearing)
These are the driveshaft seals: www.bearingshopuk.co.uk/os26x38x7mm-r23-...9wYf3zqBqBoC4QXw_wcB
  • Basketcase
01 Aug 2015 08:47 #148792 by Basketcase
Replied by Basketcase on topic where do I get wheels bearings ???????
I got mine from Jimny bits, they seem alright up to now easy to fit as well
01 Aug 2015 11:27 #148800 by facade
Busta wrote: Visit your local bearing supplier! There will be one not far from you. They are a standard bearing. They might have the seals too. If not, they can be bought online very cheaply.
They don't fit the front hubs, unless yours is special.
The front hub bearing is a single cassette type, with a split centre race. When you tighten the nut, the split closes and preloads the brearing. There is no way to adjust a pair of taper bearings, unless there is a crush spacer between them.
Look for 41X68X40/35 bearing. (I won't swear that is correct, as it is the same part as a vitara)
Loads on eBay. A bearing supplier can likely order them.
Time to create page: 0.094 seconds
