Difference between m13 and m16
  • boby13
11 years 3 months ago #148526 by boby13
Difference between m13 and m16 was created by boby13
I´ve been wondering, what´s the difference between the M series engine? It is very hard to get this engines in Costa Rica, there are mostly M13. Someone told me that what changes is the bore. If this is true, maybe I can find M16 or even M18 pistons and do a DIY stroker... I know that further mods have to be done, like bigger injetors.
Has anyone done this? Does the crank, rods, cams, etc are the same?
Thanks!
  • saboor73
11 years 2 months ago - 11 years 2 months ago #150248 by saboor73
Replied by saboor73 on topic Difference between m13 and m16
M16a are under square design block and m13a is oversquare engine m16a have longer stoke and same bore as of m13a m16a tb/injector are slight bigger cmp ckp are different
Last edit: 11 years 2 months ago by saboor73.
  • boby13
11 years 2 months ago #150253 by boby13
Replied by boby13 on topic Difference between m13 and m16
so this means that it would be fairly easy to stroke the 1.3 engine by replacing some internal parts and the throttle body? assuming that everything else on the inside fits
  • saboor73
11 years 2 months ago #150281 by saboor73
You would need block of m16a and and crank of m16a rest m13a part are interchangeable
  • boby13
11 years 2 months ago #150306 by boby13
great, thanks! hope i can find a m16 shortblock somewhere...
11 years 2 months ago #150344 by j999pre
If you fit the m16a throttle body the jimny will idle too high
Grey pick up Jimny
Time to create page: 0.090 seconds
