very loud tapping noise from the engine
- mark 88
26 Jul 2015 10:35 #148433
by mark 88
very loud tapping noise from the engine was created by mark 88
hi all about 20 miles into a journey an all mighty nasty tapping sound that increases with revs from the engine there is no drop in engine performance. i checked the cams and tappets they seem fine the sound may be coming further down. crank area. my first thought was shells but that would make the a rolling thunder noise than a knock/tap like something is hitting something its got oil in to.
any help would be great thanks
- mickt
26 Jul 2015 16:04 #148458
by mickt
Replied by mickt on topic very loud tapping noise from the engine
Small end(rod/piston connection)!
27 Jul 2015 02:36 #148494
by kirkynut
Replied by kirkynut on topic very loud tapping noise from the engine
Is it piston speed or cam speed?
If piston speed it could be piston slap. I had this on my Ignis Sport. I sold it as a result but the new owner who I told about it is still using it daily.
- mark 88
27 Jul 2015 10:35 #148506
by mark 88
Replied by mark 88 on topic very loud tapping noise from the engine
it increases as i rev it is about the best i can say i checked the compression which is fine so my valves aren't bent can i work on the bottom end from under the car once i remove the gearbox i.e remove the pistons from the bottom without removing cylinder head ?? thanks all
- OllieNZ
27 Jul 2015 11:38 #148507
by OllieNZ
Replied by OllieNZ on topic Re:very loud tapping noise from the engine
Which engine?
- Decklandpt
27 Jul 2015 15:35 #148520
by Decklandpt
Replied by Decklandpt on topic very loud tapping noise from the engine
you could on the 1.5ddis, i'm don't see a reason why you wouldn't be able to do so on the petrol one
Time to create page: 0.238 seconds
