Damaged my front axle
  • Brownie
25 Jul 2015 15:44 #148409 by Brownie
Damaged my front axle was created by Brownie
Ok so abit of over enthusiastic offroading has bent my front axle how hard is it swap over the old one for a new one as I have just ordered it today
26 Jul 2015 00:07 - 26 Jul 2015 00:09 #148423 by kirkynut
Replied by kirkynut on topic Damaged my front axle
It's easy enough if you are able to get the chassis on stands. You need a jack that goes high enough.
Last edit: 26 Jul 2015 00:09 by kirkynut.
  • Brownie
27 Jul 2015 19:51 #148539 by Brownie
Replied by Brownie on topic Damaged my front axle
hiya its going to the garage to have it done had a quote of 100 to do it as the axle i bought cme with everything hubs included so they have said it shouldnt take that long
27 Jul 2015 22:18 - 27 Jul 2015 22:20 #148548 by Johnniehec
Replied by Johnniehec on topic Damaged my front axle
As long as you've got the same axle, pre and post vvt (without Nd with ABS) have different ratio diffs, should be an easy swap.
Last edit: 27 Jul 2015 22:20 by Johnniehec. Reason: Addition
28 Jul 2015 04:15 #148563 by Lambert
Replied by Lambert on topic Damaged my front axle
When I switched my front axle tube it ought to have taken me a full day but that was everything off stripped and cleaned, it took longer though as I was miss sold the tube off an automatic transmission car so had to have it re machined to suit my differential. Tbh it's not a bad job it's all just spanners and sockets assuming you have the right replacement parts.
Time to create page: 0.083 seconds
