Jimny running poorly
  • Jackshepherd94
20 Jul 2015 17:14 #148063 by Jackshepherd94
Jimny running poorly was created by Jackshepherd94
Jus recently my jimny has started to run poorly :( it's the g13bb engine. at any speed it will jus start to jolt and judder, then if I come to a stop it will jus cut out, even when the jimny has jus been turned on, will go for a few minutes then jus cut out. I done the fault codes and got 22 throttle position sensor, 23 air tempeture sensor and 31 and 32 manifold pressure sensor. How would I come about fixing theses problems without it being too costly as I'm not wanting to spend a fortune getting them fixed when there could be a cheaper way haha. Any help appreciated :)
Cheers
  • mickt
20 Jul 2015 19:23 #148077 by mickt
Replied by mickt on topic Jimny running poorly
Did you clear the messages and then did they come back? They might have been old time messages.
20 Jul 2015 21:20 #148109 by Busta
Replied by Busta on topic Jimny running poorly
Sounds very much like the camshaft sensor needs replacing! It's a very common fault.
Time to create page: 0.074 seconds
