Battery light!!!!!
20 Jul 2015 21:16 #148106 by Busta
Replied by Busta on topic Battery light!!!!!
I have fitted new alternators in the past which have turned out to be faulty from new, so don't rule that out.
  • Lewg123
20 Jul 2015 21:39 #148121 by Lewg123
Replied by Lewg123 on topic Battery light!!!!!
All fuses are fine. Fan belt is tight. Surely there's not many things it could be.
  • Lewg123
22 Jul 2015 08:18 #148229 by Lewg123
Come one guys need help it's still on. Going to check the earths later tonight just wondering where there all located?
22 Jul 2015 08:55 #148230 by Jezz
Replied by Jezz on topic Battery light!!!!!
Broken wire? My Transit vans alt light has been on for about two or three years. I checked it was charging as it should then hit the net for research, To find it's a common fault on my van. So if you'res is charging as it should ( I hope you checked before changing expensive parts) then I'd be looking for a bad wire.
It's been fettled just a tad.
  • Daniel30
22 Jul 2015 10:06 #148238 by Daniel30
Replied by Daniel30 on topic Battery light!!!!!
If its charging maybe it's a faulty light/ connection on the warning light itself?
  • mickt
22 Jul 2015 15:49 #148260 by mickt
Replied by mickt on topic Battery light!!!!!
Have you actually checked the voltage across the battery with first the engine off and then with it running to see what is actually happening? That would help diagnosis from a distance. If you have not got a meter then a garage will /should stick a meter across it in the hope of selling you a new battery/alternator.
Time to create page: 0.108 seconds
