Reverse Light Fuse
- BigAndy
11 years 4 months ago #147980
by BigAndy
Reverse Light Fuse was created by BigAndy
Hi all.
Could someone enlighten me to the position of the reverse light fuse please. Reverse lights aren't working but both bulbs are fine.
What are the switches like to change?
Cheers
Cheers
- BigAndy
11 years 4 months ago #147984
by BigAndy
Replied by BigAndy on topic Reverse Light Fuse
I'm guessing the fuse is the one marked 'BACK'? If so the fuses are also fine. Without putting a meter across the points I can only guess it's a duff switch (hoping the wiring is fine)?
- markyp2000
11 years 4 months ago #147986
by markyp2000
Replied by markyp2000 on topic Reverse Light Fuse
Its on the gear box near the top a little pain to get to i think
11 years 3 months ago #148031
by kirkynut
Replied by kirkynut on topic Reverse Light Fuse
It'll be the switch on top of the gearbox as has been said.
You can do it by feel. You'll be able to see / feel the wires going to it.
Search for it on this forum as we recorded the spanner size to go onto the switch in one post.
11 years 3 months ago #148111
by Busta
Replied by Busta on topic Reverse Light Fuse
If it's a twin cam, as you stand in front of the car looking at the engine, the plug is to the left of the engine near the bulkhead. The switch is in the top of the gearbox. I find it's easiest to get to by laying on top of the engine and reaching behind.
It's a fairly big spanner size, so arming yourself with an adjustable might be easiest!
Time to create page: 0.088 seconds
