Rear disc conversion query
- Nelson83
11 years 4 months ago #147838
by Nelson83
Rear disc conversion query was created by Nelson83
Had my rear disc brake conversion fitted by the local garage and when they've bled the brakes, the pedal goes almost all the way to the floor rather than half way like before. They've bled the front brakes and the new rear ones, and ive crawled under and bled the nipple above the axle, yet it the pedal still seems to go a lot further down than "pre-conversion". Brake fluid level is fine and to the max line. Any suggestions?
11 years 4 months ago #147843
by Keithy
Replied by Keithy on topic Rear disc conversion query
Get them to bleed it properly.
Discs all round=zero travel here prior to brake engagement.....Hydraulics are a bit like that. :whistle:
- Nelson83
11 years 4 months ago #147844
by Nelson83
Replied by Nelson83 on topic Rear disc conversion query
the hand brake now onlyhas to do one click and its fully on - proper chuffed with that
whats the sequence for doing it properly now its got the discs on the back end? anybody care to talk me through it, so i can have a go this weekend
- steffan
11 years 4 months ago #147850
by steffan
Replied by steffan on topic Rear disc conversion query
Use a pressure bleeding system I borrowed 1 from a pal of mine and don't think al ever try anything else now so easy
11 years 4 months ago #147957
by kirkynut
Replied by kirkynut on topic Rear disc conversion query
It's always furthest away from the master cylinder first. So rear nearside first. Then rear off side, front nearside and lastly front offside.
I was going to ask if the caliper piston had far to travel before tightening on the pads but the handbrake only needing one click suggests not. Otherwise I'd wind the caliper out a little or however your calipers adjust.
11 years 3 months ago #148037
by jimkyx
Replied by jimkyx on topic Rear disc conversion query
If the bleeding finally fails - I hope not, then you might check the slave cylinder volumes of the disk calipers compared to the original drum slave cylinders. If the disk slave cylinders have a significantly bigger capacity (which was the case when I upgraded a Ford I had) then the possible cure is to upgrade the master cylinder so it pumps a grater amount of fluid for less pedal travel.
Time to create page: 0.125 seconds
