Need help please!
  • RichiesJimny
05 Jul 2015 00:17 - 05 Jul 2015 00:18 #147214 by RichiesJimny
Replied by RichiesJimny on topic Need help please!
First things to check are the transfer box mounts and the gearbox mount, try lifting the back of the gearbox if you can lift it you need a new mount.
Last edit: 05 Jul 2015 00:18 by RichiesJimny.
  • Lewg123
05 Jul 2015 20:25 #147281 by Lewg123
Replied by Lewg123 on topic Need help please!
Also fitted a new clutch last week and aslo the gear box has gone so stiff struggle to get it into 1st 3rd and 5th
  • Whaley
06 Jul 2015 04:29 #147302 by Whaley
Replied by Whaley on topic Need help please!
Hello and welcome, I had a rattling/vibration noise on mine thought it was rear gearbox mount or transfer box mount so replaced them all it was still there! just put up with it for 8 months until I changed the rear radius arm bushes last week and hay presto its now 90% better mine was only doing it from about 1500-1800 RPM mainly in second gear under load, don't know if this will help?? good luck
06 Jul 2015 08:09 #147304 by Busta
Replied by Busta on topic Need help please!
If the gearstick has gone stiff, it's very likely to be one of the mounts. Which is good news- cheap and easy to fix.
  • Lewg123
06 Jul 2015 11:06 #147315 by Lewg123
Thanks I'll try and post a video of the noise later it is extremely loud will check mounts later on
06 Jul 2015 12:13 #147317 by Busta
If it's REALLY loud, it could be a damaged prop or the prop hitting against something because a mount is broken.
Time to create page: 0.101 seconds
