Creaky Clutch
- Grego
01 Jul 2015 21:15 #147039
by Grego
Creaky Clutch was created by Grego
I Have a very creaky clutch, the creak seems to come from around the pedal ,
I've sprayed oil around the pivot but it has made no difference, could it be the cable?, the clutch is not stiff at all
Any ideas?, the thing is driving me mad.
- Nicks_Jim
01 Jul 2015 22:13 #147044
by Nicks_Jim
Replied by Nicks_Jim on topic Creaky Clutch
Clutch cable shot
- wombat
01 Jul 2015 22:19 #147046
by wombat
Replied by wombat on topic Creaky Clutch
Try disconnecting it at the pedal. pull it through into the engine bay and run some thin oil down it. Worked for me on my last jimny
02 Jul 2015 08:46 #147053
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Creaky Clutch
I have a 2nd hand cable of your interested
Grey pick up Jimny
- Grego
02 Jul 2015 17:19 #147073
by Grego
Replied by Grego on topic Creaky Clutch
Had a couple of hours to spare so disconnected the cable at the clutch end (can't even see how it connects to the pedal) , put a piece of paper in the footwell and dripped oil thru the cable until it dripped on the paper...well lubed.
Slightly quieter but definately f*****d.
I will replace it with a new one (thanks anywayJames )when I get the time and figure out how it connects at the pedal end
02 Jul 2015 18:24 #147083
Replied by mlines on topic Creaky Clutch
A new one is the only way to go. Just ordered one from my Distributor for LittleJimny which has the same problem. Heavy creaking clutch but no clutch slip or judder.
The cables are nylon lined and wear through the nylon sheath on the curve in the cable.
