Uprated radiator, Rad hoses
  • Tomhorntoad
29 Jun 2015 16:08 #146854 by Tomhorntoad
Uprated radiator, Rad hoses was created by Tomhorntoad
Does anybody do an up rated rad and or rad hoses?
Reason I ask I've been having some overheating problems. The water pump is pretty much brand new and I've just changed the viscous fan. My rad is supposedly quite new and had been cleaned out (where possible)
So now I'm thinking it could be thermostat, rad,rad hoses or cap?
29 Jun 2015 21:50 #146891 by kirkynut
I can't think it's the hoses. A new rad and thermostat will solve it I'm sure.
The following user(s) said Thank You: Tomhorntoad
  • Tomhorntoad
30 Jun 2015 07:45 #146911 by Tomhorntoad
Replied by Tomhorntoad on topic Uprated radiator, Rad hoses
Have you seen any uprated rads?
01 Jul 2015 12:44 #147008 by kirkynut
No, probably because they don't need them. Standard ones are fine.
01 Jul 2015 20:17 - 01 Jul 2015 20:19 #147030 by Rhinoman
If you've been out in mud then the fins could be clogged up but I'd have the coolant system pressure tested and then checked for gasses before I fitted uprated parts.
Last edit: 01 Jul 2015 20:19 by Rhinoman.
01 Jul 2015 20:41 #147033 by Keithy
Replied by Keithy on topic Uprated radiator, Rad hoses
Rhinoman wrote: If you've been out in mud then the fins could be clogged up but I'd have the coolant system pressure tested and then checked for gasses before I fitted uprated parts.
Are you implying that a Jimny engine could have a blown head gasket?
Oh no you dit'nt! (that last was Jimmy Carr)
Time to create page: 0.106 seconds
