waterproofing
- oxford_bloke
11 years 4 months ago #146762
by oxford_bloke
waterproofing was created by oxford_bloke
Is there anywhere on a jimmy that is susceptible to being immersed, if so how have people overcome it?
11 years 4 months ago #146773
by facade
Replied by facade on topic waterproofing
Swivel housings are not sealed, fill with water and wreck the lower kingpin bearing.
Waterproof grease, and don't go through water
11 years 4 months ago #146779
by kirkynut
Replied by kirkynut on topic waterproofing
Just add a snorkel, accept the front axle will need stripping regularly for re greasing with waterproof grease and the sliders on the front brakes seize and need re greasing regularly, or do as has been said, avoid deep water!
Or change axles of course.
11 years 4 months ago #146788
by Busta
Replied by Busta on topic waterproofing
You will need to extend the breathers for the axles, transfer case and gearbox up to above water level. You can make something up pretty easily, or kits are available.
- oxford_bloke
11 years 4 months ago #146789
by oxford_bloke
Replied by oxford_bloke on topic waterproofing
Cheers guys all fairly bog standard stuff, as much as I'll try and avoid deep water winch challenge stuff may say otherwise.
Time to create page: 0.086 seconds
