Oil leak question
- Shellie
26 Jun 2015 05:58 #146609
by Shellie
Oil leak question was created by Shellie
Does anyone know where this problem could be from. There is oil (which seems thinker than normal engine oil) which is dripping from the the passenger side, it's coating the wheel arch, a big round thing and the inside of the wheel. There seems to be oil pipes running around under there, is there a seal that often goes. Could the oil be from one of these pipes or is it more likely to be from the steering or suspension?
Thanks.
Thanks.
- rexthecat
26 Jun 2015 06:22 #146610
by rexthecat
Replied by rexthecat on topic Oil leak question
There's the brake line that runs down there I think, check the fluid level. There's a join in the wing on mine might need nipping up.
26 Jun 2015 06:52 #146611
Replied by Daniel30 on topic Oil leak question
26 Jun 2015 06:53 #146612
Maybe you could take a picture?
- Shellie
26 Jun 2015 16:34 #146640
by Shellie
Replied by Shellie on topic Oil leak question
I'm back from college now and have the car up on axle stands and the tyre off.
Yes it looks like that. I've had to come in now as the drizzle has now changed to heavy rain.
- mickt
26 Jun 2015 19:37 #146657
by mickt
Replied by mickt on topic Oil leak question
Worn king pins then.
Time to create page: 0.103 seconds
