Whine from transmission
- Longman
20 Jun 2015 16:20 #146346
by Longman
Whine from transmission was created by Longman
Hi all I've had a whine on my car for a while now only when on power no whine when coasting.I thought it was rear diff whine so have changed the diff but still have the whine.
All wheel bearings have been changed so know they are OK it seems to be worst in 4th and 5th gears any ideas what can cause the whine.
Thanks Mark
Thanks Mark
20 Jun 2015 16:35 #146347
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Whine from transmission
Gearbox or transfer box? Try it in low on a flat field and see if it's still only in 4th and 5th
Grey pick up Jimny
24 Jun 2015 15:46 #146523
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic Whine from transmission
chq oil level of gearbox and tcase
- Longman
24 Jun 2015 20:15 #146532
by Longman
Replied by Longman on topic Whine from transmission
I have changed the gear box and t case oils, levels are spot on but still got the whine I think I'm going to take the rear prop off and run it in 4 h with the front axle and see if anything changes
Time to create page: 0.127 seconds
