Bought a map reader for a quid off eBay
  • gembrand
17 Jun 2015 20:22 #146169 by gembrand
Bought a map reader for a quid off eBay was created by gembrand
Hi Chaps
My Check Engine light has been on,bought a reader off eBay and got these codes
P0135 02 Sensor heater
P0340 Camshaft position sensor and on the LIVE reading it read Fuel System Fault
Just wanted to know is it easy to put these right or should l take it to a garage :o)
18 Jun 2015 05:40 #146193 by facade
P0135 is the oxygen sensor at the bottom of the manifold, before the catalyst.
Check for loose/broken connections (wishful thinking) then fit a replacement, then clear the codes.
The cam sensor might be dodgy, but usually they don't throw up a code anyway.
Fuel system fault is likely caused by the faulty oxygen sensor affecting the ability of the system to trim the fuel.
In summary, fix the oxygen sensor.
Then worry about the cam sensor, they are an easy cheap fix.
The following user(s) said Thank You: gembrand
  • gembrand
18 Jun 2015 19:05 #146227 by gembrand
Replied by gembrand on topic Bought a map reader for a quid off eBay
Cheers mate :o)
Time to create page: 0.079 seconds
