Back door gas strut
- HARRY.B
15 Jun 2015 15:54 #146011
by HARRY.B
Back door gas strut was created by HARRY.B
Apologies if this has been dealt with before but could someone tell me how to remove the back door gas strut / damper ? The end attached to the door is easy enough as it's mounted on a pin and secured with a nut, but i cannot for the life of me see how the strut is held in place on the ball socket end. There is no retaining clip as is usually the case on gas struts and i 'm unable to see any other retaining pin/lock/device. It won't come off with gentle pressure and i didn't want to try forcing it. Any tips ???
15 Jun 2015 17:10 #146019
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Back door gas strut
Unbolt it from the shell? Similar to the How it comes off the rear door
Grey pick up Jimny
- HARRY.B
15 Jun 2015 18:48 #146034
by HARRY.B
Replied by HARRY.B on topic Back door gas strut
That would still leave the 'ball' mounting stuck in the end of the strut. There must be a way of disconnecting the two apart.
15 Jun 2015 18:51 #146035
Used to have something like this on boot lids and I think the strut could be popped off. Not 100% sure though.
Replied by helijohn on topic Back door gas strut
HARRY.B wrote: That would still leave the 'ball' mounting stuck in the end of the strut. There must be a way of disconnecting the two apart.
15 Jun 2015 18:54 #146038
by j999pre
Grey pick up Jimny
Sorry I just thought you wanted it off the car
Grey pick up Jimny
- HARRY.B
15 Jun 2015 19:17 #146045
by HARRY.B
Yeah, im taking it off as im sure it's seizing up, so i need to keep the 'ball' mounting to attach a new after market one. I would have got rid and done without but i can't see a door strap so it could prove expensive if a high wind blew the door right round and wrecked the hinges !
Time to create page: 0.106 seconds
