Cat
- troggy
11 years 5 months ago #145879
by troggy
Cat was created by troggy
Hi all.
Daughters 06 jim is sucking air into the cat, and/or blowing gas out.
The pipe from the manifold seems to go into cat, but has split a seam?
Whilst it does not seem about to fall off, as the pipe goes into the cat, and it is all holding up, do you have any advice on this one?
Bunged a load of gun gum round the joint, wrapped in chicken wire (as you do), but it keeps splitting.
Best wishes to you all, The trogmeister.
- Thank you received: 706
11 years 5 months ago #145880
Replied by jackonlyjack on topic Cat
weld it
- troggy
11 years 5 months ago - 11 years 5 months ago #145881
by troggy
Replied by troggy on topic Cat
Thanks jack, but you have not seen my welding!
Am more likely to blow a massive hole in it, or weld myself to it.
Last edit: 11 years 5 months ago by troggy. Reason: add comment
11 years 5 months ago #145882
probably about the same as mine lol only started to weld in march :whistle:troggy wrote: Thanks jack, but you have not seen my welding!
- troggy
11 years 5 months ago #145883
by troggy
Yeah, it's a fine art. thanks anyway, good luck!
11 years 5 months ago #145884
you could try J999pre on here i bet hes got a spare
Time to create page: 0.086 seconds
