Low range reduction
- X8GGY
If you just want to lower the low-range side of the box gearsets are available for the standard / existing transfer box, but many believe the Jimny transfer box with it's chain drive is not up to 'proper' offroading and the change to an SJ / Samurai box is normally recommended... it depends whether you are going to go to larger tyres later (if it's allowed in your locality)
- TomDK
maverick wrote: Transfer Box upgrade ...
probably would need to consider:
Extended Brake Hoses
Bigger Wheels/Tyres
Caster Corrected Radius Arms
Spring Lift / or god forbid a Body Lift
Lockrite
Winch
Cage
Stronger CVs
Stronger Shafts
It always starts off with a minor modification, but ends up expensive --
BUT, totally WORTH EVERY PENNY!
Like othe peoples "well Modified Jimny's", people are still amazed at where they can go -- way, way beyond those 4x4x4xFar ... we are well past that, and more!!
Why would he need all that just for a transferbox upgrade.
He needs the transferbox, mount and shafts.
- SPL
Which kit is recommended for the original transfer?
- TomDK
SPL wrote: Unfortunately, in our country it is not possible to increase the tire
Where do you live?
Trial jimny in Italy makes a reduction gearset for standard jimny transferbox.
- X8GGY
Difficult question to ask on a predominantly UK forum... as we all use rocklobster (SJ/Samurai) transfer boxes to compensate for bigger tyres...
Try DG Tuning ?
Perhaps someone from Europe could help?
I guessed right with the tyre issue then?
- SPL
I live in Israel
