Castor correction bushes
- Grego
Also, what effect would corrected bushes have if the Jim hasnt been lifted ?
I wanted to do the harder stuff first, fit extended hoses and correction bushes in prep for a 2" lift
- wombat
- TomDK
wombat wrote: If you fit correction bushes to standard jimny it will put your suspension geometry and axle alignment way out as you will be compensating for a suspension lift that has not been done. I would think it would be difficult to drive/steer and possibly dangerous :evil: :evil:
No more difficult to drive/steer and possibly dangerous than a 2" suspension lift without castor correction.
- Grego
Thats what im thinking, with a 2" lift caster correction is not needed as the effects on decreasing the caster angle are not too drastic, and I would be increasing the angle by a similarly small amount.
Also, with an SFA the caster angle will be changing all the time, under breaking, accelerating , heavy loads etc so there must be an acceptable safe spread (so to speak)
There is nothing to stop the bushes rotating per-se, however they are clamped by the axle brackets and, because the holes are eccentric, they can't turn easily when everything is bolted up.
- Grego
