pink injectors
06 Jun 2015 20:03 - 06 Jun 2015 20:04 #145551 by Rhinoman
Replied by Rhinoman on topic pink injectors
have you checked the engine number? you may have a 1.6 fitted, if you haven't then the pink injectors are not going to help your fuelling, you will be running big injector trim settings to compensate. If it is a 1.3 then I would pull one and check the numbers.
Last edit: 06 Jun 2015 20:04 by Rhinoman.
Time to create page: 0.064 seconds
