egg
  • Daniel30
25 May 2015 17:52 #144797 by Daniel30
Replied by Daniel30 on topic egg
Always fill up at shell, will have a look next time it smells many thanks for the advice
  • ZookFastback
26 May 2015 06:51 - 26 May 2015 06:52 #144830 by ZookFastback
Replied by ZookFastback on topic egg
facade wrote: First lift the bonnet when the smell starts, if it is the battery, you will know (keep your eyes away from it if it is)
Have you changed fuel brands?
I use whatever pool petrol Tescos have at the standard pump, although I try to keep away from ethanol blends.
I'd wait for a few more suggestions before you start spending money.
Why keep away from Ethanol blends mate? I've only every used E10 (10% alcohol, 95 RON) in my Jimny, from brand new 15 years ago and she has done 417,000 k's so far, still going strong.
Last edit: 26 May 2015 06:52 by ZookFastback. Reason: left a little bit out
  • JimnyGlenn
26 May 2015 07:05 #144832 by JimnyGlenn
Replied by JimnyGlenn on topic egg
417k !! Is that on the same engine?
  • ZookFastback
26 May 2015 07:29 #144834 by ZookFastback
Yep, although I replaced the head at a bit over 400,000 k's. Only had 6 things break down in 15 years. Cam angle sensor, Heater core, front axle assembly (smashed into rock at speed), rear axle assembly (smashed into different rock at speed), clutch, and something else that I can't remember. This is in addition to normal wearable items, disk pads, tyres, odd fuse and globe, radio aerial.
This is what happens when one lets the moment get away from one and goes to fast in the Flinders Ranges of South Australia ;)
26 May 2015 09:02 #144837 by facade
Replied by facade on topic egg
We are already subjected to upto 5% ethanol in the UK, and are likely to end up with 10% in the future.
Apart from it is corrosive, hygroscopic & tends to separate from the fuel in storage, I don't trust anything these "environmentalists" say is A Good Thing ;)
(Try getting paint that sticks to aluminium, we can't even buy creosote any more, people put emulsion on their sheds and it washes off in the rain :ohmy: )
  • JimnyGlenn
26 May 2015 12:42 #144842 by JimnyGlenn
That's amazing. Think I will buy one on the strength of yours ;)
