Wheel bearings ??
- Thank you received: 671
17 May 2015 10:30 #144314
by facade
Wheel bearings ?? was created by facade
Martin will confirm, but AFAIK, the difference is the retaining collar for abs has a dirty great cog on the bearing side.
Whether that means that the ABS collar is longer, and the oilseal further in the axle tube I don't know.
Daresay you could fit two collars, machining one shorter so the split isnt on the seal track if that were the case.
17 May 2015 10:54 #144316
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Wheel bearings ??
My understanding is the bearings are the same, Just the abs ring retainer being the difference. I actually use 6207 closed bearings in mine, and just pushed the coller up a bit further with no problems. I'm lucky with mine as I have removable drive flanges, So I can pull the bearing off the wheel end without removing the coller.
- Docmartin4x4
17 May 2015 11:11 #144318
by Docmartin4x4
Replied by Docmartin4x4 on topic Wheel bearings ??
I go through wheel bearings on the rear, looking at the spacer, is this just there for the oil seal to seat on and keep the oil from leaking out from the axle tubes? If this is the case a sealed bearing ie. 6207 2rs that has rubber seals incorporated in the bearing would solve this....i think.
Can you still buy the modification that was used on the SJ's that stops you having to undo the back plate and brake lines?
Mart
Mart
17 May 2015 11:18 - 17 May 2015 11:20 #144319
by Jezz
The spacer is duel purpose, It is for the oil seal to run against. But it also holds the bearing in place on the shaft, Stopping the half shaft from trying to escape from the axle. It is actually known as a bearing retainer for that reason.
Last edit: 17 May 2015 11:20 by Jezz.
- Docmartin4x4
17 May 2015 11:31 #144321
by Docmartin4x4
Can they purchased individually?
Mart
Mart
Time to create page: 0.088 seconds
