Tension impossible
  • virginian
17 May 2015 17:30 #144330 by virginian
Replied by virginian on topic Tension impossible
Nice one Mart, I'll give that one a go....If I'm successful, I'll post it
17 May 2015 17:53 #144333 by facade
Replied by facade on topic Tension impossible
Docmartin4x4 wrote: My tensioner went on my o6 jim , You can take them apart and replace the bearing, going by memory it is a 6210 2rs available for about £15/20 from any bearing distributor.
Mart
That is the size I guessed it was.
Looking at the inside of the pulley (50mm dia side, the front is larger), it does look as if it is pressed together: you can see a tiny ridge where the centre is. Whether it will press apart and go back together though.......?
  • virginian
18 May 2015 21:53 #144390 by virginian
Done some research on replacing the bearing. I've ordered a 6210 zz which is the same as the 6210 2rs but has steel seals not rubber, & costs £12.50. I will let you know if the pressing goes t..s up or not :whistle:
  • virginian
20 May 2015 21:49 #144495 by virginian
Bearing I ordered turned up this morning. Took off the tensioner in about 10 mins & got one of the workshop boys to press the old one off & the new one on, put tensioner back on as per manual, and ran the engine up......., no more 'bzzzzzzzzzz ' just a nice purrrrr :)
Time to create page: 0.103 seconds
