Help imobilizer light flashing
- Davyo
15 May 2015 12:24 #144239
by Davyo
Help imobilizer light flashing was created by Davyo
Went shooting last night,car ran sweet as a nut down to my permission 25 miles, but when driving round off road the engine and imobilizer lights stared flashing and the Rev counter needle bounced around and the power was lost.Happened twice so we left it for 30 minutes before driving it home with no problem.Took it out this morning and again after about 30mls same thing.called breakdown who hooked it up to diagnostics and there was no codes stored,so it got brought back to my local garage on a flatbed.
Been googling and there is loads of threads on this but no fixes,any ideas? Left it with my local garage for now but don't know if they can sort,poss need to take it to Suzuki.Strange this is that when this problem doesn't occur it runs and ticks over beautiful.
15 May 2015 13:25 #144242
by Rhinoman
Replied by Rhinoman on topic Help imobilizer light flashing
Sounds like a cam or crank sensor issue.
- Davyo
15 May 2015 13:41 - 15 May 2015 14:08 #144244
by Davyo
Replied by Davyo on topic Help imobilizer light flashing
That's what's comming up on most of my searches,the breakdown guys diagnostics got no codes,so hoping my local garage can pin point( none Suzuki ).If not I think I will have to get it into a Suzuki dealers
It's a M13A engine
It's a M13A engine
Last edit: 15 May 2015 14:08 by Davyo.
15 May 2015 14:21 #144247
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Help imobilizer light flashing
M13a engine? Probably crank sensor behind the alternator. Easy swap 1 10mm bolt and one connector. Just fit a new one Dave on garage fees. Garage won't be able to check it unless they take it for a run. You could always try the trick of cooling it with water as soon as it does it (the sensor) to pin point that is your problem.
Grey pick up Jimny
15 May 2015 14:24 #144248
Replied by mlines on topic Help imobilizer light flashing
And with a sensor problem you rarely get codes captured
- Davyo
15 May 2015 14:32 #144249
by Davyo
Thanks lads just waiting for a call from garage,the breakdown guy got no codes so hopefully it's only one of the sensors,might just get the garage to go ahead and change both.
