brake light fuse keep blowing
- mark 88
14 May 2015 19:27 #144225
by mark 88
brake light fuse keep blowing was created by mark 88
hi all my 15amp fuse keeps blowing after about 5 mins of driving. its got to be earthing against the metal somewhere just wondering if anyone has had the same problem and can tell me where in the harness they found the brake.
oh i have one bulb that's been blown for ages thanks all
14 May 2015 19:38 - 14 May 2015 19:46 #144227
by Halford
Replied by Halford on topic brake light fuse keep blowing
weekest part = the rubber sleave that passes from the right rear wing to the rear door, the wires are single core and very briitle (if this is where the problem is then suggest replace/bridge all wires using flex cable as they're likely to all fail, I used cable stripped from an old iron)
if it keeps blowing then maybe that's where the problem is, can you see any fish swimming around in the light fixture.
do you mean it keeps blowing or you've just left it for ages :whistle:mark 88 wrote: i have one bulb that's been blown for ages
Last edit: 14 May 2015 19:46 by Halford.
16 May 2015 16:41 #144290
Replied by helijohn on topic brake light fuse keep blowing
Did you sort this as I had a very similar problem but found it was one of the other items on that fuse circuit. When I went in to reverse in fact; the sender was flattened and in the wet the current arced across. It only happened in the wet and when I used reverse but at first I blamed it on the indicators!! :silly:
- mark 88
22 May 2015 19:52 #144690
by mark 88
Replied by mark 88 on topic brake light fuse keep blowing
its strange a fuse will last for about 20 min then pop a checked the lights there is no water in them will try turning on other lights if it causes a trip
22 May 2015 20:08 #144692
That's exactly what I had and it was because the rain took a while to short out.
mark 88 wrote: its strange a fuse will last for about 20 min then pop a checked the lights there is no water in them will try turning on other lights if it causes a trip
Time to create page: 0.099 seconds
