Problem with speedo with a lobster box
  • Jimnyjack1993
09 May 2015 22:35 #143967 by Jimnyjack1993
Problem with speedo with a lobster box was created by Jimnyjack1993
Just seeing if anyone can help me, I've fitted a lobster box and my speedo needle seems to float up and down! A can be in 5th gear and its floating from 20/40 back to 10! It's all over the shop. I have fitted the speedo gear but can't see anythink wrong in how I've fitted it but will get some pictures up toworrow to see if anyone can tell me if iv done wrong
Thanks jack
09 May 2015 22:42 #143968 by Jezz
The pick up sensor needs to be close and central to the pick up ring.
It's been fettled just a tad.
  • Rockwatt
10 May 2015 12:40 #143980 by Rockwatt
Replied by Rockwatt on topic Problem with speedo with a lobster box
The gap between the sensor and the toothed ring needs to be at 1mm
  • Jimnyjack1993
10 May 2015 19:03 #144004 by Jimnyjack1993
Replied by Jimnyjack1993 on topic Problem with speedo with a lobster box
Thank you, i will try it :)
  • Docmartin4x4
14 May 2015 15:51 #144197 by Docmartin4x4
Replied by Docmartin4x4 on topic Problem with speedo with a lobster box
I have a similar problem with my 'mini lobster set up, up 40mph it is fine but over that it will bounce around like a kangaroo on a pogo stick!!
