wont start after flat battery/80amp fuse replace
- boomstick
07 May 2015 20:27 #143852
by boomstick
wont start after flat battery/80amp fuse replace was created by boomstick
Hi can anyone help? my Jimnys 80amp fuse blew and at the same time battery was run flat after leaving lights on. I have replaced fuse and charged the battery but it still wont start, it turns over but wont fire up! any ideas?
- Riceye46
07 May 2015 20:59 #143858
by Riceye46
Replied by Riceye46 on topic wont start after flat battery/80amp fuse replace
Next to the fuse box is some little relays put your hand under there and wiggle the wires while someone starts the car heppened to me when I first got my jimny and it happened agen last Saturday had to rewire a new plug on mine it mite not be your problem but as you have bin around that area worth a try
- boomstick
07 May 2015 21:39 #143862
by boomstick
Replied by boomstick on topic wont start after flat battery/80amp fuse replace
Hi thanks I will give it ago!
- boomstick
08 May 2015 18:40 #143916
by boomstick
OK so i give it ago and nothing happened, so i took the fuse box off and the relays and found one of the wires from the relay was hanging out and one from the connectors on the fuse box, after cleaning the wires and putting new connectors on them I put it all back together and it fired up first time!!!
Thanks for the suggestion.
- Riceye46
08 May 2015 19:12 #143917
by Riceye46
No problem that's what where here for to help each other out and keep the jimnys on the road glad you got it sorted and thanks for taking the time to let us know it's fixed
Time to create page: 0.099 seconds
