Jimny pulling left.
11 years 5 months ago - 11 years 5 months ago #145329
by Halford
just be careful in the wet on bends as the rear cornering grip is likely to have reduced, mine was so bad I ended up getting new rears even though tread depth was fine
Replied by Halford on topic Re:Jimny pulling left.
OllieNZ wrote: Cheers guys,
I swapped the fronts and rears today, instantly fixed the problem
Last edit: 11 years 5 months ago by Halford.
- OllieNZ
11 years 5 months ago #145331
by OllieNZ
Replied by OllieNZ on topic Re:Jimny pulling left.
11 years 5 months ago #145332
by Halford
- JimnyGlenn
11 years 5 months ago - 11 years 5 months ago #145338
by JimnyGlenn
Replied by JimnyGlenn on topic Jimny pulling left.
Is it worth changing tyres diagonally, corner to corner periodically if the car is used in mainly 2WD? I once got told this but don't know if it's good practice or not?
Last edit: 11 years 5 months ago by JimnyGlenn.
11 years 5 months ago #145349
by Busta
Replied by Busta on topic Jimny pulling left.
If they are wearing unevenly swapping the tyres around in sensible. Because Jimny's have solid axles, a pathetic engine and weigh very little, tyre wear seems to be very consistent so there's no massive need.
With modern, heavy, FWD cars with complicated suspension geometry, front tyres will wear out long before rears so swapping tyres front to rear is much more worthwhile!
The following user(s) said Thank You: JimnyGlenn
- Lozi
11 years 5 months ago #145362
by Lozi
Replied by Lozi on topic Re:Jimny pulling left.
Time to create page: 0.108 seconds
