fitting landrover axles
  • Longman
04 May 2015 21:07 #143692 by Longman
fitting landrover axles was created by Longman
I am thinking of fitting axles off a landrover disco to my jimny had anyone fitted any to there jimnys if so what do I have to do to make them fit, some pictures would be very helpful
  • munchy
04 May 2015 23:48 #143696 by munchy
Replied by munchy on topic fitting landrover axles
fitting land rover axles is not the big problem. the big problem is getting the the correct gear ratio to match the differential ratio in the land rover axles as they are so tall you will struggle to pull away in 1st low range.
05 May 2015 07:13 #143703 by kirkynut
Replied by kirkynut on topic fitting landrover axles
This is why people use Toyota axles as the ratios are right.
Time to create page: 0.067 seconds
