engine won't start, G16B conversion
- GraphicX
28 Apr 2015 09:11 #143309
by GraphicX
engine won't start, G16B conversion was created by GraphicX
i'm in a real spot of bother, i'e put a G16B in my previously G13BB jimny & it won't start. it'll turn over but doesn't get any spark at that plugs.
in the conversion we used the cam ring from the G13BB to replace the ring on the G16B.
i've cleaned every electrical plug, checked all the earths.
removed the spark plugs, #1 is drenched with fuel, the others are all black & sooty (they are new plugs).
what are my options here for figuring this out ? i've googled, posted on the jimny facebook group & on auszookers but i'm having zero luck.
my thoughts are that maybe the cam ring is in the bad position front to back & the sensor is mission it, or that perhaps a plug is simply having a really bad connection but i've double checked them all.
any tips or thoughts would be appreciated.
28 Apr 2015 10:15 #143317
by j999pre
Grey pick up Jimny
Replied by j999pre on topic engine won't start, G16B conversion
Is your jimny a hard top or soft top?
Grey pick up Jimny
- GraphicX
28 Apr 2015 10:23 #143318
by GraphicX
Replied by GraphicX on topic engine won't start, G16B conversion
it's a hardtop, but i believe the engine/cam sensor are identical to your spanish built soft tops.
28 Apr 2015 10:40 #143319
by j999pre
Grey pick up Jimny
Check the earth on the head at the front near the cam cover on the inlet. I forgot this once and it wouldn't start.
Grey pick up Jimny
The following user(s) said Thank You: GraphicX
- GraphicX
28 Apr 2015 11:01 #143322
by GraphicX
thanks for that but i've removed them & cleaned them twice now (3 black wires that come of the loom from the injectors if i'm thinking of the correct connectors).
- suzukisam
28 Apr 2015 12:29 #143334
by suzukisam
Replied by suzukisam on topic engine won't start, G16B conversion
I would check the cam pick up ring see if has the same number of lobes think you need 11
Time to create page: 0.098 seconds
