i need a engine, but what to get?
  • Garry
05 Nov 2010 20:51 #5749 by Garry
i need a engine, but what to get? was created by Garry
my jimnys engine has been getting worse over time, i think ive finially managed to kill it tonight, so im now looking for a small diesel engine to fit,
i know of one set up i can use, but its hard to get the parts,
the one i know of is a vauxhall izuzu 1.7 or 1.5td mounted to a opel manta gearbox, i can get the engine no problem but cant get a gearbox,
what othere easy options are there?
06 Nov 2010 07:02 #5755 by mlines
I don't know about "easy" options but you would be a bit of a "Jimny Hero" if you fitted the Renault 1.5 Diesel as this is the engine fitted to the European Diesel Jimnys. Mechanically you would probably need the engine mounts and bell-housing from a Diesel Jimny which you can get from UK Suzuki parts or try from a European scrapyard, under the German scrappage scheme I understand the car part scrap yards are full of parts.
The real problem would be around the electronic controls. It is probably unrealistic to fit a Diesel Jimny loom and RCU so you would probably have to mix and match.
Would make a great write up for here!
  • Garry
06 Nov 2010 13:11 #5765 by Garry
Replied by Garry on topic Re: i need a engine, but what to get?
Im trying to keep the eletrics nice and simple,
modifiying the engine bay loom wont be a problem, ive alread modefied the entire loom to the back end, in total i reckon ive got rid of 2 or 3 dozen wires, the standard wiring in a jimny has been way over complicated
engine wise i just need something simple,
  • Bigchridy
06 Nov 2010 16:59 #5773 by Bigchridy
Replied by Bigchridy on topic Re: i need a engine, but what to get?
I've heard of people putting the 1.7 izuzu/vauxhall engine in Jimneys before but never really thought about what gearbox you would need. There must be another box you can use with that engine as Opel Manta parts are hard to come by! I will be considering a 1.7 diesel for when my engine goes pop as I can get bits cheaper through work!:) Also depending which ecu I end up using I should be able to use works diagnostic equipment to talk to it!
I've also heard of a guy locally who is running a VW 1.8 turbo in his Jimny but I have no more details so have no idea how it fits or what box he is using.
  • a18suf
06 Nov 2010 18:18 #5774 by a18suf
Replied by a18suf on topic Re: i need a engine, but what to get?
There is a company in the States that does a conversion for the Golf 1.9 diesel. They recommend a pre 1998 engine as the electrics are more basic.
  • ooky_123
06 Nov 2010 19:52 #5776 by ooky_123
Replied by ooky_123 on topic Re: i need a engine, but what to get?
Suzuki Liana is suppose to be al straight swap ... just have to swap the injection rail .. so Ive read
Time to create page: 0.085 seconds
