Steering damper
  • 2013gary
11 years 6 months ago - 11 years 6 months ago #143083 by 2013gary
Steering damper was created by 2013gary
Hi everyone,
I have just bought the Pro Comp steering damper kit from Jimnybits and am trying to fit it. What is supposed to be a 10 minute bolt-on job is proving to be quite fiddly and annoying so I think I might be doing something wrong. I've attached the chassis bracket fine, but for the other bracket it says in the instructions to fit it to the steering rod.
My first question is, have I bolted the bracket to the correct bar/rod? (see picture) or should I be using the one nearest the front diff?
Secondly, should said bar have as much play in it as it does in this video? Or do I need two new get new tie rod ends?
View My Video
Last edit: 11 years 6 months ago by 2013gary. Reason: added vid
11 years 6 months ago - 11 years 6 months ago #143085 by maverick
Replied by maverick on topic Steering damper
here's mine fitted ...
Top Tip is to measure your shocker at minimum AND maximum length and then fit with shocker at mid range.
Sorry its abit muddy underneath ... it was in a bog in the Punch Hunt last weeknd
Jalapeño, IISY?
Last edit: 11 years 6 months ago by maverick.
11 years 6 months ago #143086 by maverick
oh and YES, it is Fiddly as Fk.
Jalapeño, IISY?
  • 2013gary
11 years 6 months ago #143097 by 2013gary
Replied by 2013gary on topic Steering damper
Thanks a lot for the help. I didn't even consider putting it at mid range, I was just lining the bracket up by eye to where everyone else was putting them. I will have another go in the morning.
