Lift Kits
- rossryde
22 Apr 2015 14:32 #142956
by rossryde
Lift Kits was created by rossryde
Hi all, just bought my first Jimny last week
and looking at fitting a lift kit! Im wanting it for general road use but i do a lot of fishing and shooting so would want to be able to take it off road when I want too and not worry about damaging anything underneath!
Any help on what to go for and roughly the money it would be would be much appreciated
Thanks in advance, Ross
- darthloachie
22 Apr 2015 15:41 #142958
by darthloachie
Replied by darthloachie on topic Lift Kits
As its mainly for road use dont go above 2"
you can either go for 1.5inch spring spacers and shocker spacers for about £150
Bits4vits, jimny bits
or 2" replacement springs and shocks - will give more flex off road
jimny bits £350 upwards depending on make of shocker
you may be able to pick a used lift kit off james (j999PRE) on here
22 Apr 2015 16:13 #142962
by Busta
Welcome along!
A standard Jimny is a pretty capable machine. Just because you are going offroad, you don't need to have a lift kit. Fitting the right tyres is the most important bit. A transfer case guard may be a good investment but there's not much else that will get damaged unless you are really trying...
- Steveolkinevel
22 Apr 2015 18:58 #142968
by Steveolkinevel
Replied by Steveolkinevel on topic Lift Kits
Hi and welcome, you have made a good choice by getting a jimny! I too shoot and fish and use my jimny daily, I have a 3" lift kit with castor correction bushes extended brake lines, 32mm wheel spacers 235/75/15 insa turbo special track tyres and anti roll bar removed and other than the road noise from tyres it's fine to use daily imo.
It also goes every where I have pointed it so far,
As above though even in standard form there super off road, you would be suprised where you can go even in standard form.
ATB Steve
ATB Steve
- Jutwit
22 Apr 2015 19:14 #142970
by Jutwit
Replied by Jutwit on topic Lift Kits
Have a look in the for sale section, loads of stuff there that might be of interest to you
- rossryde
23 Apr 2015 10:15 #142999
by rossryde
Replied by rossryde on topic Lift Kits
Im thinking of getting a 2" body lift just to get the clearance of the big tyres as i have at grabbers on my jimny just now and get a slight rub when it gets bumpy or turning hard right! so the body lift will correct this am i right?
Time to create page: 0.087 seconds
