Panhard rod bushes
  • mickt
16 Apr 2015 18:52 - 16 Apr 2015 18:54 #142631 by mickt
Panhard rod bushes was created by mickt
I have just received a pair of bushes for the front rod off the shop. I have pressed the old rubber ones out on my MM press no bother. As these new ones look daughtingly bigger what is the best lubricant to use when I come to press them in? I take it they do not need trimming.
Last edit: 16 Apr 2015 18:54 by mickt. Reason: grammer correction due tired
17 Apr 2015 14:47 #142673 by Rhinoman
Replied by Rhinoman on topic Panhard rod bushes
The SuperPro bushes come with some assembly grease, with the bits4vits bushes I just used a smear of ordinary grease.
  • X8GGY
17 Apr 2015 15:50 #142675 by X8GGY
Replied by X8GGY on topic Panhard rod bushes
My bushes in a KAP Panhard -
  • mickt
17 Apr 2015 18:33 - 17 Apr 2015 18:34 #142678 by mickt
Replied by mickt on topic Panhard rod bushes
Thanks for replies. It is a Suzuki original rod. So Vaseline it is then! They are from the BigJimny shop run by martin by the way.
Last edit: 17 Apr 2015 18:34 by mickt. Reason: extre text added
  • mickt
18 Apr 2015 20:10 #142738 by mickt
Well I have fitted the new bushes. I did not realise that unlike the old style rubber bushes it replaced these poly bushes come apart i.e the centre metal tube is removable! It is still a bit tricky to push the poly part of the bush into the rod end, three hands would be a help, but with a press, white grease and a bit of ingenuity it went well. The first one went in reasonably easy but the second one was a bit of a bitch. Then the tubes were pushed in, again using the press.
Time to create page: 0.107 seconds
