fault code engine manage light on
- garrygun
11 years 7 months ago #142414
by garrygun
fault code engine manage light on was created by garrygun
Hi guys, i have engine management light on my jimny 2002 & code fault 01 pend 01.. p0135.. ive switched em light off and comes on again after a short time, could someone tell me which sensor this is please & possibly where i can get a reasonably priced one from..
Thanks Garry..
Thanks Garry..
- garrygun
11 years 7 months ago #142447
by garrygun
Replied by garrygun on topic fault code engine manage light on
thanks for that, i will look that number up see if i can get one local, unless someone on the forum comes up with one surplus to their requirements,
Cheers Garry.
Cheers Garry.
- rexthecat
11 years 7 months ago #142469
by rexthecat
Replied by rexthecat on topic fault code engine manage light on
Maybe pull the sensor off first and bench test it. It's an easy test and will save you quite a few quid if it's not the sensor. Other faults will cause an O2 sensor fault code. Could be a vacuum leak maybe. Just a thought, my o2 sensor has been a complete and costly pain
- garrygun
11 years 7 months ago #142575
by garrygun
i didnt think you could test these unless you have the expensive equipment, if it ispossible what readings should i get?
Thanks Garry.
Thanks Garry.
Time to create page: 0.079 seconds
