Adjustable panhard = terminal death wobble
13 Apr 2015 08:36 #142371
by Rhinoman
Adjustable panhard = terminal death wobble was created by Rhinoman
I fitted the front JB adjustable panhard at the weekend but now sometimes when I hit a bumpy bit of road I get terminal death wobble, the car shakes violently and is completely undrivable, all I can do is de-clutch brake and then set off again from stationary, fortunately it has only happened on a straight road. Has anyone else had this issue? I bought the polybush kit with the panhards, do the stock bushes fit?
- X8GGY
13 Apr 2015 14:07 #142382
Replied by X8GGY on topic Adjustable panhard = terminal death wobble
Is that all you have changed Rhinoman? Nothing else?
Interesting that the DW's can come on with just the change of the panhard rod and presumably SuperPro bushes?
13 Apr 2015 14:29 #142383
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Adjustable panhard = terminal death wobble
I've had shocking death wobble due to panhard bushes before. The car was jumping around. I had fitted a replacement poly bush when it should have had a proper metal encased rubber bush. It was quite scary. Make sure you have the correct bushes for your type of rod.
Grey pick up Jimny
13 Apr 2015 15:03 - 13 Apr 2015 15:07 #142384
by Rhinoman
Replied by Rhinoman on topic Adjustable panhard = terminal death wobble
The SuperPro bushes were supplied by JB with the panhards. I will order some standard bushes and the stock panhard will go back on when I get home, its too dangerous to drive it as it is.
Last edit: 13 Apr 2015 15:07 by Rhinoman.
- Whaley
13 Apr 2015 15:34 #142385
by Whaley
Replied by Whaley on topic Adjustable panhard = terminal death wobble
Might sound daft but did you tighten the bolts up fully ? I left one loose when i did mine and when i got to 30 mph i thought i was going to die!!
13 Apr 2015 15:46 #142386
by Rhinoman
Definitely tightened.
Time to create page: 0.107 seconds
