Cam sensor
11 Apr 2015 21:51 #142320
by Rhinoman
Replied by Rhinoman on topic Cam sensor
The following user(s) said Thank You: chillisteve
12 Apr 2015 08:34 #142333
by kirkynut
Replied by kirkynut on topic Cam sensor
if it runs ok with the new cam sensor, leave it alone. I cannot see why the timing would be out and surely the ECU can cope with it being the tiniest amount out.
If you go touching the timing you might make it worse than better and wish you'd never touched it.
12 Apr 2015 11:57 #142337
by Rhinoman
The ignition timing is very important to the efficiency of the engine and should be set correctly. The disadvantage of running the timing from a cam sensor and not a crank sensor is that it is susceptible to errors if the head gasket or timing belt have been changed or if the belt is stretched, that's why Suzuki built in an adjustment. Its not a difficult job to do and the resistor is a plug in component, its a lot easier than setting points.
- GraphicX
12 Apr 2015 12:31 #142339
by GraphicX
Replied by GraphicX on topic Cam sensor
reading the service manual now rhinoman linked, the information regarding the ignition resistor begins on page 493 & sounds very easy & really worthwhile. from what i can gather, it has an identical result to manually turning a distributor on a none electronic ignition engine, but it is merely a case of unplugging one resistor & popping in another of the desired value.
where we could easily source these resistors i'm not entirely sure, but it wouldn't be difficult i'm sure.
Time to create page: 0.094 seconds
