Wheel bearing
  • Jimnyjack1993
11 years 7 months ago #141890 by Jimnyjack1993
Wheel bearing was created by Jimnyjack1993
Hello all, i have fitted a new front wheel bearing today and just wondering if I should leave a tiny bit of play when I put it back together as i have told to do by a friend, is this right?
Thanks jack
11 years 7 months ago #141891 by mlines
Replied by mlines on topic Wheel bearing
No is the simple answer.
Its a roller bearing with no adjustment, it should be done up to the recommended torque 220Nm whilst rotating the wheel.
The following user(s) said Thank You: Jimnyjack1993
11 years 7 months ago - 11 years 7 months ago #141893 by facade
Replied by facade on topic Wheel bearing
Your friend is referring to taper rollers, as fitted to Proper Cars from The Olden Days B)
These you did up until there was just a trace of play (actually, you were supposed to measure the endfloat with a dial gauge).
The front bearing on a Jimny is a one piece cassette type, with the centre race split in the middle. When you do the nut up tight, the split closes and correctly preloads the bearing.
Some eBay sellers sell a pair of taper roller bearings for the Jimny, these are wrong, and won't fit properly.
Last edit: 11 years 7 months ago by facade.
  • Jimnyjack1993
11 years 7 months ago #141894 by Jimnyjack1993
Replied by Jimnyjack1993 on topic Wheel bearing
Thank you for the help
Jack
Time to create page: 0.089 seconds
