tie rod bend again
11 years 7 months ago #141724 by safari
tie rod bend again was created by safari
hi i keep on bending my tie rod (the one on the rear) i made a custom one made of steem pipes with bigger diameter and gage but bend it again :ohmy: any one here done any modification on where it pass was thinking of trying to bend it in some way so to be more out of the way any ideas will help
tks mark
if u worry u die if u dont worry u still die so why worry
11 years 7 months ago #141737 by kirkynut
Replied by kirkynut on topic tie rod bend again
I've never heard of the standard one being bent before!
  • Longman
11 years 7 months ago #141738 by Longman
Replied by Longman on topic tie rod bend again
Had a new rear panhard made today made from 22mm solid bar
11 years 7 months ago #141746 by Lambert
Replied by Lambert on topic tie rod bend again
Only issue with making one thing stronger is that any severe loading is transferred to the next weakest point which is fine until it damages something that is not easily accessible or is expensive to replace. It's often a good idea to have some sacrificial components that are fairly cheap and simple to replace to make life easier in the long run.
11 years 7 months ago #141760 by safari
Replied by safari on topic tie rod bend again
the problem is that as soon it bends a bit it goes in the gardian shaft and eats the bolts it is 22 mm solid bar so i can not see how to stenghten it more :unsure:
11 years 7 months ago #141767 by kirkynut
Ah, I miss understood - you mean your rear panhard rod!
You need to buy these as the standard ones are very weak:
www.jimnybits.co.uk/shop/jimny/suspensio...arm-set/prod_23.html for right hand drive
www.jimnybits.co.uk/shop/jimny/suspensio...m-set/prod_1400.html for left hand drive
Everyone uprates these with no ill effects.
I cannot remember which side of the road you drive on in Malta - but I know you have some wonderful rallying!
Time to create page: 0.106 seconds
