Electrical nightmare
- gaz3359
31 Mar 2015 19:29 #141734
by gaz3359
Replied by gaz3359 on topic Electrical nightmare
Just take the bulbs out for the reverse lamps this will get you by or there is the connector for the reverse lamp switch located on top of the gearbox bit fiddly to get at.are they on just when its running/ignition on or al the time with the keys out ?
- blackpaint
31 Mar 2015 21:16 #141740
by blackpaint
Replied by blackpaint on topic Electrical nightmare
The reverse lightS come on as soon as the ignition is turned. Also I have just noticed that the 'left your lights on' beep has stopped working too.
- gaz3359
31 Mar 2015 21:22 #141741
by gaz3359
Somethings deffo up id take the bulbs out to get you by id also be onto the garage giving them a bit more of a hard time its something they have done whilst carrying out the matrix change its not like your booking it in for the first time with that fault.
- trextr7monkey
01 Apr 2015 11:19 #141758
by trextr7monkey
Replied by trextr7monkey on topic Electrical nightmare
Under the circumstances it would not be unreasonable to ask for a courtesy car if they can't sort it quickly
Good luck
Good luck
Time to create page: 0.128 seconds
