O2 sensor
  • rexthecat
11 years 7 months ago #141584 by rexthecat
O2 sensor was created by rexthecat
Had this problem for ages where when the engine gets to operating temp it looses power. Didn't seem to get the check engine light coming on normally but one time did. Pulled a code off for an O2 sensor fault. Replaced the O2 on the manifold and at first seemed to work. However on the run back home same fault came back, nightmare, however atleast the check light came on so there would be a code to read.
Was thinking of getting a code reader myself as guy I know with reader miles away. But that means I need to get a PC laptop too.
But was thinking, there's 2 O2 sensors isn't there? The other by the cat, could that be a culprit? What that sensor called?
I know its sensible to get the code first, but it's more money and the bluddy thing owes me a fortune already.
Its a 1999 hard top G16b, replaced the cam sensor and there's no crank sensor on thoes engines right?
Cheers
11 years 7 months ago #141588 by j999pre
Replied by j999pre on topic O2 sensor
But a cheap eBay code reader. Than you will know
Grey pick up Jimny
  • rexthecat
11 years 7 months ago #141589 by rexthecat
Replied by rexthecat on topic O2 sensor
Will that work ok for a 1999? Thought it was a pre obd2, Im just going from odds and ends Ive read though, may well have got that wrong, cheap sounds good.
Ta
11 years 7 months ago #141591 by Rhinoman
Replied by Rhinoman on topic O2 sensor
1999 is OBD1 and only has one sensor.
  • rexthecat
11 years 7 months ago #141592 by rexthecat
Grand ok thanks ill prob go the cheap laptop way then. Would I need that ALDL adaptor for mine then do you know? Thanks
11 years 7 months ago #141634 by Rhinoman
The 12-pin (ALDL) adapter cable is only for pre-1996 models.
Time to create page: 0.090 seconds
