Exhaust fitting kit
  • Back in Black
11 years 7 months ago #141467 by Back in Black
Exhaust fitting kit was created by Back in Black
Afternoon,
Finally getting around to fitting a new cat to Jimny, but, I can't find a fitting kit; nuts, 4 long(ish) bolts and springs that attach the cat section to the down pipe and the back section of the pipe (current ones are knackered/corroded)!! Does any one know where I can get some? I've looked on BigJimny store? Ive got the gaskets for both joins.
I need to buy another sensor thingy too as the old one is never coming out and still be working. Found one on ebay for £12.
11 years 7 months ago #141469 by jackonlyjack
Replied by jackonlyjack on topic Exhaust fitting kit
have you cut away the cat so you can get a good grip on the sensor nut
11 years 7 months ago #141496 by j999pre
Replied by j999pre on topic Exhaust fitting kit
I have some good 2nd hand bolts or alternatively they are on eBay for about £8 each
Grey pick up Jimny
  • mickt
11 years 7 months ago - 11 years 7 months ago #141522 by mickt
Replied by mickt on topic Exhaust fitting kit
The nuts are part of the exhaust pipes, or should be! Try some heat on the sensor as well as what the member earlier suggested to get it in a vice if you can.
Last edit: 11 years 7 months ago by mickt.
  • Back in Black
11 years 7 months ago #141538 by Back in Black
Replied by Back in Black on topic Exhaust fitting kit
Unfortunately while cutting that I've managed to now grind the wires!! :(
11 years 7 months ago #141543 by j999pre
I think I have a bank 2 lambda sensor also
Grey pick up Jimny
Time to create page: 0.094 seconds
