Noisy Tappets
- Aspinall-8772
25 Mar 2015 08:52 #141301
by Aspinall-8772
Noisy Tappets was created by Aspinall-8772
My 1.6 engine was making a loud tapping noise which i suspected which was tappets. I adjusted them to the set measurements. Since then the tapping noise is still there and quite annoying
What do you guys think it could be ? Or shall i just leave it ?
25 Mar 2015 10:01 - 25 Mar 2015 10:05 #141302
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Noisy Tappets
A little end bearing can sound like a rattling tappit when they start letting go. You need some sort of stethoscope to listen whether the noise is up top or farther down.
Last edit: 25 Mar 2015 10:05 by Jezz.
- nevilleb
24 May 2015 13:46 #144743
by nevilleb
Replied by nevilleb on topic Noisy Tappets
Hi Aspinall
Check the idler bearing on the drive belts in the front of the motor - it can make a ticking noise if nearing the end of its
Service life ..... Particularly if it's running dry ( no grease left)
Regards
Nevilleb
Regards
Nevilleb
Time to create page: 0.077 seconds
