EGR Valve
  • virginian
24 Mar 2015 19:23 #141271 by virginian
EGR Valve was created by virginian
Sorry to pester the forum with Newbie posts, but I'm trying to get these pesky jobs done before I tax the Jim for next month :blush:
Ran the Jim round for a bit with trade plates to settle the new parts down, and an EML came up which corresponds to EGR Valve fault.
I've done the search route which told me not much :( ...location, removal, and cleaning is my next challenge......help! :unsure:
24 Mar 2015 19:27 #141272 by Rhinoman
Replied by Rhinoman on topic EGR Valve
They are normally quite reliable, does the EML come on straight away or after its been driven a while. Straight away means a wiring issue or bad EGR stepper motor, while driving usually means a clogged EGR or passageways.
  • virginian
24 Mar 2015 19:51 #141276 by virginian
Replied by virginian on topic EGR Valve
Yeah..., thanks for you interest Rhinoman.The fault code was cleared and didn't reappear on startup and idle. When driven for a mile or two the EML popped up again. From your summary, I would guess the valve needs cleaning. The Jim had only done 1200 miles of mainly short trips the year before I purchased it.
24 Mar 2015 19:55 #141277 by j999pre
Replied by j999pre on topic EGR Valve
I have g13b and m13a used get valves if you get stuck
Cheers
Grey pick up Jimny
The following user(s) said Thank You: virginian
  • virginian
17 Apr 2015 19:46 #142690 by virginian
Replied by virginian on topic EGR Valve de-gunging
2005 M13a Egr removal..... disconnect neg terminal on batt. Egr valve is to the left of the coolant temp sensor at the rear end of the rocker box. Carefully press the clip and remove grey plug from the top of the valve with the help of a mirror. Trace the stainless steel pipe, that feeds back from the l/h side of the valve to the fuel injection unit, & remove the 2 bolts plus s/s gaskets at each end, leaving just the 2 bolts holding the Egr valve to the rear end of the engine. Care taken with the fibre gasket on the valve will save having to replace it on installation. After removal, clean out the Egr unit with a suitable cleaner/toothbrush/pipecleaner combo until the valve moves smoothly up & down. (The valve is literally a valve. ) Replace Egr valve in reverse order without leaving too much knuckle covering & bad language in the process. You will have large difficulties with the installation of the s/steel gaskets and.... after completion of this operation.... you will understand why there isn't a lot of detail on request :blush:
Checks for continuity etc are abundantly covered in the manual.
Time to create page: 0.089 seconds
