panhard bolt torque?
11 years 7 months ago #141184 by Lambert
panhard bolt torque? was created by Lambert
Hi can someone with a service manual please tell me the torque setting for the panhard to axle bolt and the panhard to chassis bolt please thank you.
  • markyp2000
11 years 7 months ago #141197 by markyp2000
Replied by markyp2000 on topic panhard bolt torque?
Tight should do also add some grease to the bolt where it goes through the bush as thay can corrode together
11 years 7 months ago #141198 by Lambert
Replied by Lambert on topic panhard bolt torque?
Tight makes it give a lump in the steering, really tight makes it squeaky and 3/8th buzz gun makes it click and snap going over bumps so I was hoping to find the actual torque figure and try again.
  • mickt
11 years 7 months ago #141203 by mickt
Replied by mickt on topic panhard bolt torque?
The MM call it the lateral rod. The front one is 65 lb ft as is the rear. Tighten with vehicle in non loaded position on the ground.
11 years 7 months ago #141243 by Lambert
Ok all torqued up and all seems to be correct. Cheers for the input guys.
Time to create page: 0.083 seconds
