Lift
- chillisteve
Also i can afford the 3 inch lift kit and hoses but need to save up for the rest. Will the car be safe to drive with standard tyres on untill i can get the castor kit?
Thanks
Steve
So wait until you've saved up enough for a 3" lift and get that.
It'll be safe on small tyres and a 3" lift but will look odd.
I'd imagine if you tot up the prices of everything individually this will be a money saver www.jimnybits.co.uk/shop/jimny/suspensio...t-kit/prod_1009.html
- TomDK
I had a 4" ORA lift which only lifted the Jimny around 2" due to winch, cage batteries and such. Now I have heavy duty diesel springs from Trail Master. They are the same lift, but much stiffer.
TomDK wrote: 235/75 15 Will do just fine on a 2" lift. Just consider getting diesel springs if the Jimny gets loaded with cage, winch and such. There's no point in getting a 3-4" lift if the actual lift is only 1½-2".
You say that Tom but only if he fits non aggressive Mt tyres. He'll have no chance of fitting anything like Malatesta or Insa Turbos in a 235/75/15 and some non aggressive ones will rub like buggery.
I have Bigjimny 3" springs and they are at least a 3" lift if not more with a winch and a cage and I don't need diesel springs on the front. I think 4" is getting too long personally.
- TomDK
You say your 3" lift gives an actual lift of 3". But is that compared to a completely standard Jimny without which, cage etc. Or is it compared to a standard Jimny with said equipment installed?
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
Gary
