Speedometer Problem - Mechanical to electronic
- irishpaddy
11 years 8 months ago #140555
by irishpaddy
Speedometer Problem - Mechanical to electronic was created by irishpaddy
Guys,
I'm almost finished fitting a XUD 1.9 engine and an LDV gearbox to my Suzuki Jimny. I am having a problem with the speedometer. The LDV box has a mechanical speedo drive while the Jimny has a electronic speedometer.
Does anyone have any suggestions on a work around that will be successful.
11 years 8 months ago #140556
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Speedometer Problem - Mechanical to electronic
Get a toothed ring made to go on the output flange of your transfer box. Then use the jimny Speedo pick up to read it. Job done
What transfer box are you running?
Grey pick up Jimny
The following user(s) said Thank You: irishpaddy
- irishpaddy
11 years 8 months ago #140557
by irishpaddy
Replied by irishpaddy on topic Speedometer Problem - Mechanical to electronic
Standard transfer box. Thanks for the advice
11 years 8 months ago #140560
by j999pre
Grey pick up Jimny
The Speedo should work fine as is in the standard box just ensure its wired correctly, probably through the standard jimny ecu
Grey pick up Jimny
- irishpaddy
11 years 8 months ago #140561
by irishpaddy
I'm not using the jimny ECU.
j999pre wrote: The Speedo should work fine as is in the standard box just ensure its wired correctly, probably through the standard jimny ecu
11 years 8 months ago #140562
by j999pre
Grey pick up Jimny
But you could to run the clocks and Speedo
Grey pick up Jimny
Time to create page: 0.088 seconds
